Issue with 22' at WOT >
Old 09-26-2011 | 10:41 PM
Default Issue with 22' at WOT
Finally got my 22 with stock 454 to run at 140 degrees steady by installing a transom external pickup (turns out the intake tube on the bravo drive wasn't allowing enough water).
So now I'm only running 4100RPM at WOT with a rebuild 454. MSD distributor, holley carb, stock heads and cam.
Prop is a brand new 24P 4 blade Mirage. Runs 58.5 mph.
I'm thinking I should go to the 23P Mirage plus? But I probably need to pick up 500 rpms?
Is there something I'm missing since others with this setup are running 25P mirages and getting close to 70mph?
gumbya55 is offline
