where is OIL Bypass valve? >
Old 04-30-2004 | 02:51 PM
Default where is OIL Bypass valve?
I'm confused, is the bp valve in the block on a '97 502 or is it in the bolt on oil filter/ cooler adapter? No more ? after this I promise.
kennyo is offline
Old 04-30-2004 | 06:11 PM
It's in the block, in the filter
adapter pad area, just in front
( towards the front of the engine)
of the center opening ( where a
oil filter would thread on)
Hope this helps.
jt
JaayTeee is offline
Old 04-30-2004 | 09:36 PM
RLW
Why is it needed?
RLW is offline
Old 05-01-2004 | 03:59 AM
So if the filter gets clogged, the oil will circulate past it.
Old 05-01-2004 | 04:00 AM
BTW, thats what it's for. Whether or not its really needed is up for debate.
Old 05-03-2004 | 05:22 PM
Turbojack's Avatar
Bypass goes in round hole that is at 1 o'clock (has lip) on filter pad. As you can see, oil comes from oil pump to oblong hole, thru filter & then to engine. If filter is pluged then oil goes thru bypass on side & then to engine.
Turbojack is offline
Old 05-04-2004 | 10:37 AM
thanks, problem solved.
kennyo is offline
Noise Pollution
1
11-20-2007 10:33 PM
paulkairis
8
07-27-2007 11:56 AM
boatman747
2
10-20-2005 06:53 PM
Waterfoul
7
07-03-2002 09:58 AM
traviss
10
06-10-2002 06:16 PM
