My new 2007 30 SKater
#131
The data was collected by hand. My son-in-law, an aerospace engineer helped me. I am
also a classically trained aerospace engineer, who spent most of my career as a systems
design engineer, before becoming a professional race boat driver. After retiring from
racing, I continued as a systems design engineer.
It is good to know I am not the only one whose RPMs are off, side to side.
Without digital technologies, it is difficult to see the RPM variance between motors;
however, engine sync gauges have been around a long time, so who really knows.
Don’t use trim to adjust RPM between motors. Having the motors at different trim
angles could be dangerous in certain situations. I use my throttles to balance the RPMs.
Delta Tach = different in RPMs between system view and Livorsi Monster Tach, for each motor
% flow = percentage increase/decrease in GPH, STBD GPH to PORT GPH
(1-(PORT-GPH/STBD-GPH))*100
Delta Sys Tach = difference in RPMs between PORT RPMs and STBD RPMs on system view
These 3 calculated fields help me to express and understand the data, in a systemic way.
One could say these 3 fields synthesize the data into useful comparisons.
#132
. Good luck with the boat.
#133
Pretty cool stuff you calculated! I can not believe they are off in rpms like that. Have you tried to send the props out to adjust for that? One more thing, please tell me how you can make a earning career out of boat racing. I always heard the only way to make a small fortune in boat racing is to start with a large fortune
. Good luck with the boat.Marylandmark has a concept with the same motors, he has 200RPM off.
We tried 5 different sets of props, see post #129, this thread, and the 15x32 3 blade cleavers, labbed, are the ones my boat likes.
I never said I made money racing, it was just what I did. If I could make money racing, I would still be racing. I made tons of money doing the engineering thing, before racing, spent obsene amounts of money doing the racing thing. Racing was great, but it was not cheap.
#134
They were just Mercury labbed props? Or did you send them to someone? I have had good luck with Brett at bblades. I would think he could get them to run the same. Has anyone asked Mercury what is the reason for the rpm difference?
#135
I've heard from several Mercury guys that it is common to have one motor stronger then the other. Even if I got another 200 rpm out of the weaker motor, I would gain minimal speed. I'm convinced these 30 Skaters with 300XS are 102mph boats, period.
#136
My current props are Mercury 15 x 32 , 3 Blade cleavers, labbed. I sent them to Brett at BBlades asked him to tweak the starboard prop to put more cup in it to bring it down in RPM to match the lower reving motor(port). Mine is still off, 6000 port, 6200 starboard.
#138
Two of the props we tried, were borrowed, and I do not know who worked them. I beleieve that one came form Gary Ballough, and one came from Dan Lawrance.
Both myself, and Chris at Skater, have been trying to get answers from Mercury Racing since May 2007.
#139
If you look at my data in post#153, this thread, you see that of the 4 wot runs; in 2 the PORT was slower than STBD, and in 2 the PORT was faster that STBD. All of these runs are with the props spining in.
#140
Brett and Bblades is the Prop God!
The 300xs stops making is HP at 6150 and then it starts retarding.
The 300xs has several components that can cause irregularities in performance.
1. The exhaust seems to be directed towards the wing plate causing a reverb problem which directs water into the back of the cowling. It may seem barbaric but place a rubber tube in it and direct over the wing plate this will help.
2. AT wot I have found that you need 18lbs of water pressure for the computer to keep the power on.
3. The Rpm's on the cat are commonly affected by crabbing. Sometimes to keep the boat straight it requires a slight turn of the wheel this will reduce speed and rpm's on one side.
4. Depending on hours the Aircompressors output may affect top end performance.
Bottom line is that the 300xs requires larger props than 34's to get all the performance out of them. They are however very user friendly and reliable. You put a set of 300x's on the 30 skater and hold on brother.
Like I said my boat has slowed down considerably with the xs.
Brett will be making me a custom set of wheels (36") very soon and you may try them if you wish.
Dan
Dan
