Go Back  Offshoreonly.com > Owners Forum > Powerquest
Help with bunks on a 29 Enticer >
Old 05-08-2005 | 03:19 AM
Enticer Rick's Avatar
From: Lake St Clair Metropark, Harrison Township, MI
Question Help with bunks on a 29 Enticer
If anyone with an Enticer could take a measurement on there trailer bunks (inside) I would really appreciate it. Spent a couple hrs trying to get the boat to sit right. No 100% sure I like where it is located. Its on a hoist, so when I bring it up I want it to fall into place.
Enticer Rick is offline
Old 05-08-2005 | 11:19 AM
Default Re: Help with bunks on a 29 Enticer
Rick does this help?
Tom
Attached Thumbnails Help with bunks on a 29 Enticer-colleen-boat-lift-006.jpg
boatnt is offline
Old 05-11-2005 | 11:11 AM
boatnt
My bunks are set more like this. What do you think? There more vertical. Do you have a picture of your trailer bunks? I'm eventually going to purchase a trailer.
Old 05-11-2005 | 11:16 AM
dockrocker's Avatar
Let me take a pic of my trailer when I go down to pull the plate off it. Unfortunately, I don't have a pic of mine on the trailer.
dockrocker is offline
Old 05-11-2005 | 07:24 PM
Rick
bunks are under the outer lifting strakes.
click on the picture you should be able to see it.
Attached Thumbnails Help with bunks on a 29 Enticer-trailer-pictures-007.jpg
boatnt is offline
Old 06-28-2005 | 09:00 PM
This really isn't a reply to your question. But i do have a question maybe you could help me out. I have a 1999 29 Enticer with 310 7.4 mpi twins it does around 65+ mph I need some feedback on installing supercharges on the engines. Some people told me the 29 doesn't like speeds over 70mph, so supercharging is a waist of my time? If this is true?How can i make the 29 handle better @ 70 + mph? Is it possible. By the way i have a Manning dual axle 10000lb bunk trailer with the boat on it now if you need pics. Thank for listening. Paxtonsc
paxtonsc is offline
Old 06-29-2005 | 11:10 PM
Boatnt,
I see you have 4 blades on your boat what engines do you have and what size 4 blades. I have 310 7.4 mpi's and am looking to put 4 blades on mine. Right now i have 3 blade bravo's 25 pitch. Paxtonsc
paxtonsc is offline
Old 06-30-2005 | 06:48 AM
Originally Posted by paxtonsc
Boatnt,
have the same set up as you
i have bravo 1 26 pitch 4 blades
boatnt is offline
Old 06-30-2005 | 07:30 AM
Did you have 3 blades on your boat and did you notice a difference @ high speed after switching? Someone suggested 24 4 blade should i try the 26 1st. What rpm are you spinning with the 26's @ full throttle. Thank you for your input. Paxtonsc
paxtonsc is offline
Old 07-01-2005 | 01:36 PM
I had the 25 mirage plus 3 blades,the boat did about 66.5 on gps and was at about 4550 rpms.
with the bravo 1 -4 blades the boat runs at about 4450 rpm and 65mph on gps.
again thats with 1/4 of a tank or 3/4 of a tank and 2 or 6 people ,weight doesn't seem to make a difference.
but the boat handles so much better with the 4 blades.
I have my 3 blades in the garage now for about 3 years collecting dust.
I spoke with Gene @ Throttle-up his top prop tech (Julie) said to go with 4 blade Bravo 24 pitch. Paxtonsc ( I'm going to do more testing and try to get a GPS top speed and RPM this weekend to make a better determination for what prop to select).
paxtonsc is offline
Kent Perroux
13
06-19-2010 04:20 PM
Strip Poker 388
1
01-10-2008 12:59 PM
ROADHOG
16
12-24-2007 06:14 AM
Chris288
9
11-03-2006 02:52 PM
Lucky
04-14-2004 10:59 PM
