Prop results, Y2K >
Prop results, Y2K
Prop results, Y2K
Old 07-17-2005 | 06:26 PM
Default Prop results, Y2K
Got the chance to try a new prop this weekend. Motor is a 540, don't know HP but been estimated around 575. Got the boat with a 26 4 blade bravo1. Tried a 25 Hydromotive P-5 X5 Blade
I have not had a chance to compare WOT #s because I have an oil leak and not used to the boat yet, but here is what I got
bravo
3500 rpm 45 mph
5400 rpm 76-78
Hydro
3500 rpm 51 mph
5200 rpm 76 mph, had more left in it
I think I will be able to see 80 when I know how to run the boat better.
Pure Energy is offline
Old 07-17-2005 | 07:19 PM
Superbabi's Avatar
Default Re: Prop results, Y2K
Pure Energy Whats Your Top Rpm Before Rev Limiter Kicks In ????
Superbabi is offline
Old 07-17-2005 | 07:33 PM
The rev limiter is set @ 6200. This is a carbed 540 custom built, but not for me. It's power is made between 4200 and 5400 rpm. Not sure "where" max rpm is. I still need a lot more seat time!
Old 07-17-2005 | 08:11 PM
Stormrider's Avatar
JC Performance Engines
6mph increase at cruise!!! Thats nice!
Stormrider is offline
Old 07-17-2005 | 08:59 PM
FASTERDAMITT's Avatar
Get that leak fixed so we can see some top end numbers
FASTERDAMITT is offline
Old 07-18-2005 | 07:41 PM
tripps's Avatar
Hey faster,thats GOOD power!!! tripps
tripps is offline
Old 07-19-2005 | 01:26 AM
Thanks Tripps. Have you seen the engine on my thread?
Old 07-19-2005 | 08:56 AM
If your power starts going down at 5400 then you should prop for 5400. What gear is in the drive 1.5 or 1.36? When I had my bravo setup my gear was 1.36 also with a 540 and spinning 5400 with a 26. Never tried other props.
z.zuperboat is offline
Old 07-19-2005 | 09:16 AM
Pat McPherson's Avatar
I believe he's running a 1.5 lefty...
Zup, why do you guys run left hand props?
Jcap also runs a lefty...
Patrick
Pat McPherson is offline
Old 07-19-2005 | 09:33 AM
Rumor has it the lefts are faster than the rights because it equalizes the mota torque. I purchased a right but it turned out to be a left. The price was rite so I couldnt *****.Althouigh now I should because props are very hard to find.
