temp
Old 07-26-2005 | 11:28 AM
KCHOTBOAT's Avatar
Charter Member #737
Default temp
What temp. is to hot for painting. It have been in the upper 90's around here and was wonder if I should wait for it to cool down a bit.
KCHOTBOAT is offline
Old 07-26-2005 | 12:13 PM
glassdave's Avatar
Neno the mind boggler
Default Re: temp
what type of finish are you spraying? the can be a big problem for some.
08 OPA High Points Champion
glassdave is offline
Old 07-26-2005 | 12:29 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: temp
imron is what I sprayed this weekend. The paint never seemed to flow well.
Old 07-26-2005 | 12:51 PM
Wally's Avatar
Were doomed!
Default Re: temp
well i know 100 is too hot to be working with bondo!!!! by the time i was done mixing the hardener it was starting to kick!!! i ended up putting the bondo and hardener inthe fridge for a while then mixing it together...gave me just enough time to put it on the golf cart i'm workign on
-Wally
Wally is offline
Old 07-28-2005 | 09:44 AM
glassdave's Avatar
Default Re: temp
make sure you have the slowest reducer they make for it. thats about all ya can co for the heat
Old 07-28-2005 | 01:20 PM
littledcsrodshop's Avatar
Default Re: temp
Like dave said use the slowest redecer you can get. I do know that the newer Imron doesn't flow out as well as the older stuff did, even in ideal conditions. The larger area you are painting the more problem you are going to have, if the reducer is not hot enough.
littledcsrodshop is offline
Old 07-28-2005 | 02:14 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: temp
Looks like I have screwed up then. The paint store sold me the paint and activator. The can didn't say anything about a reducer. All is said was 3 parts paint and one part activator. I found a old can of Imorn which I used on the trailer and it mention using a reducer
Old 07-28-2005 | 02:39 PM
Default Re: temp
Depending how old your old can of imron was, it is probably not the same. I think the new stuff does just call for the paint and activator. However if I was determined to use it I would add a little bit of a good grade reducer. (a high temp reducer)
have already painted it ? ,what are you painting? how big of area?
Old 07-28-2005 | 03:14 PM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: temp
Painted the transom of the boat. I still have plenty of paint left over. Guess I will see how if looks after I color sand it and buff it. I have only used imrom a couple of times and the other two times it came out great. This has more orange peel than I would have liked.
Old 07-28-2005 | 03:58 PM
Default Re: temp
I think the orange peel is probably due to the new style imron
vs. the older stuff. If you spray it again you might want to try
adding a little reducer.
