Bow Nav. lamp out >
Bow Nav. lamp out
Bow Nav. lamp out
Old 08-08-2005 | 11:46 AM
Ran-Dom 32's Avatar
Default Bow Nav. lamp out
changed the bulb - still not working??? anyone have an idea how to access to wiring to it?? '99 35 - possible fuse blown??
Ran-Dom 32 is offline
Old 08-08-2005 | 12:35 PM
BZ's Avatar
BZ
Default Re: Bow Nav. lamp out
I could write a book on that silly light, I would take the mirror off at the head od the bed. you can get the wires easy that way. start there and if you have questions pm me for more I am on my 3rd light and tons of time replacing/messing with it....BZ
BZ is offline
Old 08-08-2005 | 01:22 PM
Wally's Avatar
Were doomed!
Before tearing appart the boat i would take a volt/ohm meter and check the wiring at the light. You can learn alot just from the wires. It can tell you if you have a bad ground or if theres no 12v+ Hell you may just have corroded contacts behind the light underneith. Another very common problem ive seen on boats was the switch. ALOT of boat companys use the spde connector splitters which tend to fall off sooner or later.
-Wally
Wally is offline
Old 08-08-2005 | 01:35 PM
Downtown42's Avatar
Mine broke quick too. Inside the anchor locker about 2-3ft to the rear the wire junction came un-plugged. That was it!!!
Downtown42 is offline
Old 08-08-2005 | 01:49 PM
Ran-Dom 32's Avatar
It appears there is no power @ the lamp(tester12v), bulb contacts look nice & clean, Look like I have to trace the wires back. -switch lights up on the dash & rear anchor light still works
Old 08-08-2005 | 07:03 PM
Ran-Dom 32's Avatar
Problem solved, the conection came apart, new conector & good to go, thanks for the help.
Old 08-08-2005 | 08:53 PM
Downtown42's Avatar
Old 08-08-2005 | 09:07 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Mine did same thing. reconnected and secured it better.
US1 Fountain is offline
Old 08-10-2005 | 10:55 AM
I had to take the pimp mirror out to fix the wiring.......its good now... doug
pullmytrigger is offline
nordic95
Drives and Lower Units
1
07-27-2008 09:22 PM
eliminatethis
Boating Safety
8
11-27-2007 07:51 PM
MacGyver
Powerquest
5
05-20-2007 12:03 PM
offthefront
07-11-2005 11:34 AM
Stepin-Up
Velocity
1
09-07-2003 07:49 AM
