Fuel Injection retrofit >
Old 08-29-2005 | 09:34 PM
Default Fuel Injection retrofit
I've got a 555" N/A carb motor with a little over 600 hp, and I am considering converting to EFI this winter. Can a late 90's Mercury EFI be modified to work properly with this engine? I've got a good amount of experience with automotive EFI, but not marine. Any help would be appreciated. Toolz
toolz is offline
Old 08-29-2005 | 09:58 PM
MAG502NUM
Default Re: Fuel Injection retrofit
Yes, if you build the engine around the fuel injection, instead of building the engine and then trying to adapt the FI system to it. Big inch engines are good canidates for factory efi set ups (ie: tuned runner) because of this systems limitations with higher rpms and a better idle quality...cam timing being equal of course.
Old 08-29-2005 | 10:32 PM
MAG502NUM -
Are you talking the Black engine EFI system or the Blue engine EFI? I have wondered if my 502 mag could at rebuild time feasibly be made into a 540 similar to what toolz is doing with good EFI results.
BGIII is offline
Old 08-29-2005 | 10:44 PM
articfriends's Avatar
Originally Posted by BGIII
MAG502NUM -
I used the factory (2000 efi mpi 502 ) efi system to make 950hp/ft lbs tq w/procharger on a 540,people say its not big enough for a 540 but i disagree. Do a search for my efi thread,Smitty
http://www.offshoreonly.com/forums/s...d.php?t=103922
articfriends is offline
knotrated
1
05-02-2008 03:49 AM
Noise Pollution
21
06-11-2007 10:09 AM
blownboat
12
02-08-2005 04:45 PM
jackbequick
3
09-21-2002 09:23 PM
meander77
1
05-14-2002 02:34 PM
