Removing SOME of the hook.  Opinions? >
Old 10-03-2005 | 10:29 AM
onesickpantera's Avatar
Default Removing SOME of the hook. Opinions?
Moved the post to this section and added a pic.
I am thinking about removing the hook on the inside of the outer strakes only. My thinking is it will loosen the boat up at high speed but will still have the hook between the outer strake and chine for stability in rough water and keep it from porpoising in the mid-range. The hook was intentionally put there.
Thoughts and opinions?
Attached Thumbnails Removing SOME of the hook.  Opinions?-transom-bottom-wording.jpg
onesickpantera is offline
Old 10-03-2005 | 10:43 AM
DirtyMoney's Avatar
Default Re: Removing SOME of the hook. Opinions?
I would leave it and play with props instead.
DirtyMoney is offline
Old 10-03-2005 | 10:44 AM
Dave M's Avatar
Veteran: Navy
I'd consider adding some tabs before trying to modify the hull.
Dave M is offline
Old 10-03-2005 | 10:46 AM
Tried quite a few. Turbo 1 24 and 25, Turbo 2+2 24, Mirage Plus 23 and 25, Solas HR 22 3b(It was suppose to be a 24, but they sent me the wrong one), Laser II 25 and Viper 23.
Old 10-03-2005 | 10:48 AM
Well, with the hook built into the hull the boat needs no tabs with the way it is. Obviously if I modify the hull it might.
Old 10-04-2005 | 08:24 AM
No one has done this?
BadDog
Baja
11
04-05-2007 06:57 PM
BOATING ON A BUDGET
Detailing, Painting, & Fiberglass
27
12-10-2005 12:03 PM
pachangalpina
Fountain
1
01-26-2004 01:26 PM
johnnyboatman
2
08-11-2002 11:24 AM
B.R.S.
Fountain
14
04-26-2002 02:28 AM
