#6 Prop Lock
Do you have any problem with it loosing up. If you look close at the Bravo3 prop lock the base of the nut has a 45deg taper to it. The washer for the prop doesn't match the base of the nut. I am concerned there is not enough contact area between nut and washer.
Airpacker,
I thought about that but was concerned that there would not be enough of the threads/nut left. It looks like you would be reducing the area of threads by ~20%.
When I discussed this idea with McGuard they didn't thing it was a good idea. Any thoughts on this???
Rick
Rick
Strip Poker 388
05-23-2006 11:28 PM
