353 Anchor Locker?? Anyone find an anchor that fits? >
Old 04-06-2006 | 06:59 AM
Default 353 Anchor Locker?? Anyone find an anchor that fits?
Hello all -
I bought a Fortress that was recomended for my size boat and it doesn't fit in my locker. It's a real pain in the a$$ to put it together each time I want to use it ( I usually wait to raft off someone). Anyone know which one will fit and hold my 353 for an overnighter?
pwrbotr is offline
Old 04-06-2006 | 07:08 AM
Default Re: 353 Anchor Locker?? Anyone find an anchor that fits?
I like the Fortress, but sometimes having to put it together gets a little nerve wrecking. I still like to be able to stow it away compacted.
Donzi Corleone is offline
Old 04-06-2006 | 07:56 AM
wrinkleface's Avatar
I had a 312 and 353 and found those lockers 2 B only good for a couple lines and smaller fenders! Plus did not want an anchor banging around in there. I also had the Fortress, ended up w/ a large tote bag and would put it in that "whole" then slip it in the starbd. side storage area in the cockpit. Worked great 4 me. If U want 2 throw off the front, wife would hand me the hook and chain on port step over pad and I would take it to the front and heave! Pain but it worked! Good luck! Wrink
wrinkleface is offline
Old 04-06-2006 | 08:14 AM
t500hps's Avatar
21 and 42 footers
I have a 312...same anchor locker. I finally found a claw type anchor rated for the boat and held AWESOME...Too bad the first time we got into some 3 footers it punched 3 holes in the bottom of the locker.
Now I carry the rope and chain with a quick connect in the locker and the anchor in a side compartment behind the seats. (Actually I usually wait for someone else to bring out their anchor first too!!! )
t500hps is offline
Old 04-06-2006 | 05:34 PM
pwrbotr is offline
Old 04-07-2006 | 07:37 AM
Thanks Troutly. I assume cutting my Fortress would be ok then.
pwrbotr is offline
Old 04-07-2006 | 09:10 PM
Fountainclimber's Avatar
An other small anchor that works is Digger.
www.diggeranchor.com.
I had one on my 29 Fountain and it fit in the small anchor locker and it worked well. I am going to try one on the 38 this year as the Founain model that is supposed to fit is hundreds.
Fountainclimber is offline
Old 05-28-2010 | 03:06 PM
i have the fortress and cut it 2 fit works perfect
bgdann is offline
Old 03-02-2021 | 02:11 PM
Veteran: Navy
The Anchor Locker on a 292 is in name only. Back seat it.
AmiableDave is offline
Old 03-02-2021 | 04:16 PM
Very small but agree 2'
Nothing personel 353 is offline
f311fr1
Black Thunder
9
06-16-2018 09:40 AM
Sneaky Fast
04-03-2008 05:44 PM
Stalkin
Cigarette
6
04-02-2007 09:07 PM
kjm5125
04-19-2006 08:45 PM
Advantage
Baja
7
04-26-2002 07:37 PM
