Stainless marine exhaust gaskets  ????? >
Old 06-27-2006 | 12:13 PM
Default Stainless marine exhaust gaskets ?????
Couple of questions
What type of gaskets do I use for stainless marine manifold to head? What type for risers?
Also Gen VI motor mount for 29scarab.
What type bolts to block?
Had someone on the board show me the one to use on the L brackets in the engine bay. Think it was that one with the stud and 2 bolt holes on the outside.
Thanks,
29scarab is offline
Old 06-27-2006 | 01:25 PM
ratman's Avatar
Default Re: Stainless marine exhaust gaskets ?????
go to your local spped shop and match up the correct felpro gasket set. i run the gen 3's and they take a larger the normal gasket with the square hole. if you have the smaller manifolds i think the use stock dimension square hole type.
ratman is offline
Old 06-27-2006 | 01:56 PM
nocigarette's Avatar
Yup Yup Dont Waste Your Money Ordering Them You Will Get Boned At The Boat Store... Local Speed Shop..........
Make Friends With Those Guys You Will Be Seeing Them A Lot.......lol...
nocigarette is offline
Old 06-27-2006 | 03:09 PM
articfriends's Avatar
My stainless marine hi tq 3's use a mr gskt 5913 (large port,sq port),they are pretty durable and run 20$ a set,yours may be the mr gskt 5910's. Spend the extra 10$ and get the "ultra-seals",they don't burn out as easy. If you measure your exhaust ports and pm me I can check if they are the 5913's or the 10's as I keep a extra set of 5913's on the shelf and can measure them,Smitty
articfriends is offline
fast22
7
10-07-2008 07:05 PM
ziemer
1
04-03-2008 08:27 PM
US1 Fountain
6
11-22-2005 07:17 PM
US1 Fountain
3
02-21-2005 09:49 PM
Pismo10
35
01-07-2005 09:03 PM
