X dimension ? >
X dimension ?
X dimension ?
Old 07-05-2006 | 10:59 AM
KCHOTBOAT's Avatar
Charter Member #737
Default X dimension ?
I am sure my X dimension is on teh high side now with out running the IMCO drive extension that I use to have on the boat. What prop should I run or should I use a spacer to lower the drive? My hdyro 4 blade just blows out and the boat will nor place out. I put on my 4 blade trophy outboard prop on the boat and it now planes out but take longer than it did before when I had the extension on the boat.
KCHOTBOAT is offline
Old 07-06-2006 | 08:40 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: X dimension ?
As discussed I would try a few other props prior to buying a spacer. Ultimately you may need to space the drive down but let's try some other 4 and 5 blades first.
[email protected]
bbladesprops is offline
Old 07-06-2006 | 08:45 AM
KCHOTBOAT's Avatar
Charter Member #737
Default Re: X dimension ?
Brett thanks for your time on the phone. I did measure the the drive and sponson and it is not as bad at I had for thought on the height. I will can you next week. Thanks again for all your help.
Black Wishbone
Sutphen
4
03-11-2008 07:02 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
375stinger
Cigarette
0
11-10-2004 04:56 PM
Bajaforce
Baja
2
03-05-2003 08:09 AM
sambryce
5
03-04-2002 05:27 PM
