Tow vehicle options
Old 09-19-2006 | 03:50 PM
Default Tow vehicle options
I'm thinking of moving towards a larger boat in the near future... probably around 10k lbs plus trailer. What are some good options for a tow vehicle that can pull such a heavy load? I like the space of a SUV, so I don't know if I'd like the confines of a pickup....
synack is offline
Old 09-19-2006 | 04:10 PM
Default Re: Tow vehicle options
I would suggest a diesel crew cab pickup or a diesel Ford Excursion.
Magic Medicine is offline
Old 09-19-2006 | 04:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Chevy 2500 Suburban w/ 8.1L gas
GMC 2500 Yukon XL w/ 8.1L gas
Chevy 2500 Avalanche w/ 8.1L gas
Ford Excursion w/ V10 gas or 6.0 PSD or 7.3 PSD
Sydwayz is offline
Old 09-19-2006 | 04:20 PM
FOUNTAINIII's Avatar
03-05 EXCURSION WITH A 6.0 POWERSTROKE PULLS A LOAD GREAT AND WHEN YOU ARE NOT TOWING THE FUEL MILEAGE IS GREAT I AVERAGE 16-18 NOT TOWING THAT IS 75-85 ON THE HWY NOT TO MENTION THE RANGE THE FUEL TANK IS 45 GALLONS
FOUNTAINIII is offline
Old 09-19-2006 | 04:39 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Or perhaps the Dodge MegaCab 2500 or 2500.
Sydwayz is offline
Old 09-20-2006 | 09:28 AM
So basically, if I want an "SUV" I have to go several years used as they don't seem to make them anymore with strong engines. Otherwise, I can get a pickup of any sort.
synack is offline
Old 09-20-2006 | 09:40 AM
Wobble's Avatar
SORE MEMBER
A vehicle with a positrac rear end at the least. 4wd would be better for that weight on a ramp.
Naturally I would recommend a 06/07 Duramax/Allison powered pickup as it is the most powerful and reliable power-train combination at the moment. I may be biased though, out pulling and out dragging my buddies Ford's and Dodge's has distorted my perception
Wobble is offline
Old 09-20-2006 | 10:40 AM
Registered User
I have 2 diesel Excursions. 10K is alot to pull with one. Stock they are kind of mushy and have ther tendency to wander. I put Superduty suspension and Firestone air bags under both. It helped alot. Still not nearly as stable as pulling with a dually. I've seen a couple of dually conversions on Excursions but that sort of shoots it for a daily driver.
Chris Sunkin is offline
Old 09-20-2006 | 11:43 AM
How are the big pickups when used as a daily driver? If I go with one of them, I'll have to drive it daily in the wintertime. Any issues with snow in the bed? Or do most just cover the bed with something?
synack is offline
Old 09-20-2006 | 04:46 PM
Synack- The 2006 Suburban or GMC Yukon XL w/ the 8.1 liter engine can be had real cheap right now and have the power. They have a 12000 lb towing capacity. They are hard to find, don't build many- use www.gmbuypower.com. I have the Avalanche version, that works also.
The Excursion is being killed by Ford, but has the diesel- Stay AWAY from the V10 gas in the Excursion -IMHO it's a Pig motor.
I think GM will offer a diesel SUV in 2009 or so.
Buy American
Wannabe
wannabe is offline
