Tow vehicle options
12-13K real lbs is the limit of what I would tow regularly with a SRW. with a CC diesel it puts you up around 20K GCWR...that's plenty for a SRW
I gave up the SUV for a F-250 PS, King Ranch loaded up, got the short bed crew with a rear bench. I added a fiberglass locking cover and put a bed rug in the back. I'll tell you that I enjoy driving this better than my Suburban. The mileage is comparable while not towing, better than the Suburban while towing. I use the bed for tools and luggage. Lots of room in the cab. I chose the Ford primarily because of the interior ammenities. The Power Stoke 6.0 is a question mark. My origninal 04 had lots of problems. My 06, zero problems. I tow 11-12K and I'll tell you that this is as much as I would tow without a dually. I don't think I would want to go back to a burb.
My SRW Crew GCWR is 22,000 lbs.
My rocket-brain has done the math, and tells me that is still 2,000+lbs. more combined wieght capacity than what I do fully loaded with fuel ect.
Good tires, monster hitch, the right tounge wieght, no problem.
Originally Posted by synack
Hows about this... ar eyou guys with the big trucks able to pack the truck in the garage?
Need to have a big garage. Mine won't fit.
I double checked the 10k lbs figure and I see that 10000 is the dry weight. With 173 gals of fuel and 30 fresh water this will put me at just under 12000 for the boat alone. Looks like I'm in diesel territory.
Dave
