gas sender unit >
gas sender unit
gas sender unit
Old 09-28-2006 | 10:42 PM
AIR TIME's Avatar
gas sender unit
okay my ground is good, the needle will not move on the gauge so I put a new one in since I will be changing all this winter I put the test light on the red wire on the gas tank still didn't move so is in the sender in the tank float sticking it is a 88 baja?? thanks
AIR TIME is offline
Old 09-29-2006 | 08:30 PM
AIR TIME's Avatar
Default Re: gas sender unit
I posted this last night at 3.30am doesn't make cent too me i am getting a new sender sat that should fix it
AIR TIME is offline
Old 09-29-2006 | 08:36 PM
Ground the sending unit wire directly. The gauge should go full scale. If it does, then it's probably the sender. If not, check gauge power (because you already changed the gauge).
Liberator21 is offline
Old 09-29-2006 | 09:10 PM
AIR TIME's Avatar
Thumbs up Re: gas sender unit
yes thanks thats what I am doing in the moring. while testing the boat I am tied of topping off the tank 100gals I think I AM AT 60 TO 70 NOW GALS. THATS Plenty thanks again art
AIR TIME is offline
Old 09-29-2006 | 10:44 PM
I also am thinking of replacing my sending unit. It reads full until I burn off about 40 gallons. I'd like to find something more accurate. Any suggestions anyone?
Thanks,
Steve
Revd Up is offline
Old 10-01-2006 | 10:19 AM
Too Old's Avatar
The Livorsi sender is the way to go for accuracy.
Fred
Too Old is offline
Old 10-02-2006 | 04:47 AM
AIR TIME's Avatar
thanks fred checking on monday to make sure thats it then I'll call yah art
AIR TIME is offline
Old 10-02-2006 | 07:48 AM
mrv8outboard's Avatar
coolrunning racing
Artie, when you store the boat for the winter make sure you use all of you gas. Leave the tank empty for the winter. You should also be using Startron in your fuel.
mrv8outboard is offline
Old 10-02-2006 | 09:21 PM
AIR TIME's Avatar
Re: gas sender unit
HEY JEB I DROPED MY PHONE IN THE WATER GIVE ME A CALL OR LEAVE YOUR # OH and yes it was just dirty wires putting it back in tuesday. going out wens, I hope if a buddy will tow me .
AIR TIME is offline
JBoat
07-01-2008 05:42 PM
Fast Forward
Powerquest
8
02-21-2007 08:57 PM
mcraymond3
4
07-26-2005 03:54 AM
Danny_Ocean
4
04-05-2004 10:47 PM
27 FOUNTAIN
26
02-11-2002 06:36 PM
