Class 5 Trailer Hitch
Old 02-01-2007 | 04:51 PM
Default Class 5 Trailer Hitch
Just bought a 3500 Duramax to pull our 382 Fas3Tech. What is the best place to buy a quality class 5 hitch/ reciever mount for the truck?
PremierPOWER is offline
Old 02-01-2007 | 05:32 PM
duunoit's Avatar
Default Re: Class 5 Trailer Hitch
I bought a Putnam for my Ram 2500. I'm pretty happy with it. It uses 2" draw bars. Here is one for your truck for $170...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8074394477
duunoit is offline
Old 02-01-2007 | 05:35 PM
t500hps's Avatar
21 and 42 footers
Local Ford dealer......My 07 F350 came with a class V
t500hps is offline
Old 02-03-2007 | 01:49 AM
Hitch Biz is my Biz.
Putnam makes the only straight tow 2" class 5.
Buy a new one at any Uhaul on special order. Or Ebay... Or hitch web.
You could also get a double receiver Torklift that will haul up[ to 17.5K off the double receiver.
Putnam hauls 15K and m16 with Weight distribution, and has the ballmounts and hitch balls to accommodate up to that capacity.
No one else supplies those capacities in a production 2" receiver. You could also could go with a 2-1/2" Titan receiver from Reese/Drawtite.. Capacity to 12K.+ more with weight distribution. OEM Factory stuff is way more $$
The Putnam is the best price. Torklift the best hitch and reese/drawtite the best name. Suggest whatever you buy matches up capacities wtih ballmount and ball.
Good in Beaverton
BBKRISH is offline
Old 02-03-2007 | 07:04 AM
Scott B's Avatar
Read the data plate on the hitch VERY carefully...
Just got the Putnam for my F350.. Nice piece.. I believe on the GM version there is a bit of welding you have to do to install, the trailer connector bracket or something?? Buizilla just put one on his, PM him for details if he doesnt see this...
Scott B is offline
Old 02-03-2007 | 07:09 AM
and warranty too I hope.
just bustin yer balz.
Rippem is offline
Old 02-03-2007 | 07:19 AM
Putnam XDR here. Search this forum. Recently did a pictorial of my set-up. If you don't need the seven-pin, just get a 4 pin end pigtail (available anywhere Hoppy brand or whatever), plug it into the harness T up under the truck and lock tie the flat 4-pin plug to the bottom side of the bumper with a thin spacer. There are some small holes in the bottom of the bumper that work perfect for this. You can barely see it but can pick it out in the pics I posted. and yes, I lost the rubber cap.
Sydwayz hole drilled his bumper one side of the plate for 7-pin and surface/flush mounted...nice
Rippem is offline
Old 02-03-2007 | 07:23 AM
t500hps's Avatar
21 and 42 footers
Apparently some come with 2 inch class 3's, but this is a 2.5 inch class V.
t500hps is offline
Old 02-03-2007 | 07:25 AM
t500hps's Avatar
21 and 42 footers
5 year or 100K drive train....5 year or 60K on the truck. Since it's for towing only I'll only get in 25-30K miles in 5 years of warranty.
I like the GMC package just fine....it's the dam dually beds I hate.
t500hps is offline
the super-duty's do come with a monster hitch...it's a Reese Titan I'm sure.
Rippem is offline
