454 ignition module >
454 ignition module
454 ignition module
Old 02-28-2007 | 03:33 PM
Default 454 ignition module
will the ign module from an ' 89 model 330 hp interchange with a '96 model 330 hp motor. Both were carb engines
kennyo is offline
Old 02-28-2007 | 04:26 PM
It should, as long as both are TB IV modules.
Griff is offline
Old 03-01-2007 | 06:46 AM
offthefront's Avatar
should work cept the 89 wont have Rev limiter ....
offthefront is offline
Old 03-01-2007 | 10:01 AM
Dave_N's Avatar
Assuming you use a module with an appropriate advance curve for your engine, a Thunderbolt IV ignition module will work with the Thunderbolt V dist.
You will need the correct wire harness (not the main harness just the small dist to coil sub-harness). In addition to the loss of the rev limiter, you will also lose the knock monitoring, Mean Best Timing, and idle speed control of the T-bolt V.
Dave
Dave_N is offline
Old 03-01-2007 | 06:40 PM
No Thunderbolt IV modules have a rev limiter. Rev limiters with TB IV's were on Merc Racing/Blue engines only and are a separate component and can be added or removed.
Griff is offline
shawn
07-16-2008 05:12 PM
Ran-Dom 32
9
09-26-2007 03:55 PM
tjsmk8
5
07-23-2007 08:03 AM
TROUBLE MAKER
15
07-28-2004 07:00 PM
US1 Fountain
6
05-27-2002 11:32 PM
