Bravo 1 to X or XR >
Bravo 1 to X or XR
Bravo 1 to X or XR
Old 03-01-2007 | 03:01 PM
Default Bravo 1 to X or XR
Can a Bravo 1 be swapped out for a Bravo X or Bravo XR without changing the transom mounting?
Do all three have the same X-dimensions?
Michael
Michael1 is offline
Old 03-01-2007 | 03:43 PM
Yes
HighPriority is offline
Old 03-01-2007 | 04:36 PM
offthefront's Avatar
Michael
The X-dimentions might be the same but the assemblies are different .. a Bravo I will work on a HP but the XR drive will not work on a Standard BI assembly .. I think ...
I know that the HP's dont have the provisons for Senders (who cares) ....
http://biggunsmarine.com/product_inf...3032479fc83091
offthefront is offline
Old 03-01-2007 | 05:38 PM
t500hps's Avatar
21 and 42 footers
As I understand it.......An XR will go into a regular Bravo transom, the XR will not but only because the bearing needs to be changed to the XR version.
t500hps is offline
Old 03-01-2007 | 06:34 PM
The transom assembly will work. You have to change a couple things. I think merc makes a kit for it.
The drives when installed will give the same propshaft depth.
Griff is offline
Old 03-01-2007 | 06:45 PM
You will need to change the gimbal bearing and the aliminium sleeve. Did it last winter changed from Bravo 1 ('87) to a Bravo X ('01)
Hydrolift is offline
Old 03-01-2007 | 07:12 PM
Pat McPherson's Avatar
Yes, you can bolt a HP drive to a standard transom assembly as stated above. There is a kit from Merc to do just that. New bearing, sleeve, and spacers for the pistons as to not over trim the bigger U-joints.
Patrick
Pat McPherson is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
