oil pressure >
oil pressure
oil pressure
Old 03-02-2007 | 04:45 PM
Default oil pressure
I have a 180 hp 4cyl that I just noticed is pushing oil up and out of the dipstick at high rpms does anybody have any ideas as to what might cause this?
Keithsta42 is offline
Old 03-02-2007 | 07:28 PM
Vinny P's Avatar
I hate the winter!!
Try this test.. Get the engine to normal operating temperature. Take off the oil fill cap from the valve cover and rev up the engine a bit. See if there is smoke or pressure pumping up through the hole. If so, most likely the rings are worn out. Time for a new engine..
Vinny P is offline
Old 03-03-2007 | 02:20 AM
Blow by caused by bad piston rings more than likely or if you're lucky, possibly a bad PCV valve if it has one.
Griff is offline
Old 03-03-2007 | 06:35 AM
nocigarette's Avatar
blow by.....How many hours on the motor
nocigarette is offline
GoCiggie31
7
08-19-2007 06:07 PM
dockrocker
17
08-05-2005 09:30 PM
mleslie951
27
11-08-2004 08:03 PM
FlyFast
13
05-10-2004 11:39 PM
