Where can I get Gil manifolds pressure checked >
Old 03-24-2007 | 01:51 PM
Default Where can I get Gil manifolds pressure checked
I think I have a manifold that is leaking or possibly cracked. Where, or can I get them checked?
jeff1000man is offline
Old 03-24-2007 | 03:08 PM
jeff32's Avatar
NAPA ? I'd call them and ask.
jeff32 is offline
Old 03-24-2007 | 03:25 PM
Payton's Avatar
Charter Member #927
Do it yourself, If you have it off the engine. Simply hook a water hose to one end and plug the other. You should be able to get 35-50 psi that way. That's more than your engine water pump will make.
Payton is offline
Old 03-24-2007 | 03:28 PM
I can try that.
Old 03-24-2007 | 05:51 PM
kaama82's Avatar
I've checked alot of manifolds using air, Just plug one end, put air to the other side, with some sort of gauge so you can see if the pressure drops when the air is turned off, real easy...
kaama82 is offline
35 White Lightning
Fountain
2
07-13-2007 02:25 PM
35 White Lightning
Fountain
0
07-08-2007 02:56 PM
shawn
10
09-18-2004 11:59 AM
stevejohns
5
07-04-2002 12:09 AM
Madmax
3
05-01-2002 08:28 AM
