Mirage + drive trimming
I recently purchased a new Mirage + 23p. My old prop was a Mirage standard.
Love the new prop and have seen about 3 mph gain and better control, holeshot, everything. Trimming the new prop is taking some getting used to, though. My old prop had this perfect and easy to find sweet spot. The new Mirage + seems harder to find that sweet spot. Moreover, drive trim was so important with the old prop, now it seems that trim doesn't effect the new prop as much...
Guess it will just take some getting used to.
btw, I gained HUGE mid-range hook-up value. Almost a different boat! With the old prop I had to positive trim to get speed, but then the bow got light and the boat was all over the place. Now, I can positive trim only slightly and still get speed, but the bow is planted and the boat feels so much more secure.
Love the new prop, but still learning it.
The M+ props have many possible adjustments if the trim switch is being too agressive.
Is the WOT rpm where it needs to be?
[email protected]
[email protected]
I've seen your new ride down there on the lift. it looks pretty nice! I'll see you on the river!
