trs rubber boot question >
Old 05-15-2007 | 05:23 PM
Default trs rubber boot question
On my TRS drive, it has the rubber boot that is outside the engine compartment covering the drive shaft. Is this suppose to have a small slit at the bottom to allow water to get out? I don't think so, but when doing an inspection saw that it had a small slit at the bottom.
thanks,
jon
jvschlegel is offline
Old 05-15-2007 | 05:36 PM
Drive Shaft/U Joint Bellows is the part in question. It has a slit at the bottom.
Old 05-15-2007 | 05:53 PM
scottc's Avatar
NO. Pull the drive and greese the u-joint and gimble bearing. Hopfully no damage yet. Replace the bellows.
scottc is offline
Old 05-15-2007 | 05:59 PM
Only got out 4 times last year for a total of 6 hours of running time so I am optimistic about it.
Do I need the bellows tool to put this on?
Old 05-15-2007 | 07:52 PM
Pwrbt33's Avatar
No bellows tool is needed but make sure you reach in and check that rear bearing in the transmission tailstock. If its hard to turn or you feel ANY rough spots it needs to be replaced.
John
Pwrbt33 is offline
Old 05-15-2007 | 09:07 PM
make sure you use bellows adhesive on your new rubber!
sschafee01@snet.net is offline
Old 05-15-2007 | 10:02 PM
After getting off line with work I went out and pulled the outdrive.
Bellow is damaged as stated above. No drive oil or tranny oil in the bellow. So that looked promising.
Carrage bearing is shot (rear bearing in the tranny tailstock), so replacing that.
O ring/metal gasket for outdrive oil transfer (can someone tell me the name of this so I can order) is on it's way out the door. If you look at the bell housing in my mercruiser manual they call it a "o" Ring.
the yokes are good, still have grease on them.
I noticed when taking the trim cylinders off if I touched my screw driver from the cylinder to the outdrive I could produce a little spark. I am certain this is not good as well. Any ideas?
BDiggity
Drives and Lower Units
11
09-28-2008 12:31 PM
egrus
3
05-27-2008 02:35 PM
greg bakker
07-10-2007 12:08 PM
SinkorSwim
04-02-2005 03:34 PM
cartman
11
06-10-2003 12:04 AM
