06 42 Exec w/ 600Sci's Prop Choice???? Help?? >
Old 06-25-2007 | 08:46 PM
Question 06 42 Exec w/ 600Sci's Prop Choice???? Help??
I just got a 2006 42 executioner with Mercury 600s, I bought 6-blade Herring's but they're horrible, I'm not sure of the size and pitch I gotta check the hub, but I was only getting 82 mph out of the boat and planing was horrible...put the stock bravo props on the XR drives and I hit 91 no problem...doesn't make sense to me...anyone out there have a similar set-up and some prop advice?!?!? please help?!?!
BacklashNJ is offline
Old 06-25-2007 | 08:53 PM
is that true gps speed and wut is dry weight on that boat just curious
fountainguy214 is offline
Old 06-25-2007 | 09:30 PM
Stormrider's Avatar
JC Performance Engines
check w/ f-n-i-guy... he had one w/ same setup.
Stormrider is offline
Old 06-25-2007 | 10:30 PM
Ask Bo ! Bo knows!
Fanatic is offline
Old 06-26-2007 | 11:34 AM
Single With Twins's Avatar
I have a 99 42 Lightning with 600 Innovations and currently running five blade 29 Hydromotives. Great out of the whole, only revs up to 2500rpm, dont have to get on it and no blow out, mid-range is solid and at just over 5000 rpm running high 80's. Haven't done WOT check on GPS.
Hope it helps and good luck;
Jay
Single With Twins is offline
Old 06-26-2007 | 11:36 AM
Downtown42's Avatar
91 should be GPS....weight is 10,300#.
Downtown42 is offline
Old 06-26-2007 | 04:33 PM
TRL505's Avatar
When you find out the size and pitch on the Herrings...let me know I may be interested in buying them. You can PM me. FYI the 2nd Gen hull you are running is very different than that of Single With Twins 99 hull...it would be hard to draw an infernece from that. It might help if you figure your slip and go from there. That boat should probably be a honest mid 90's boat with the right setup and ideal conditions.
TRL505 is offline
Old 06-26-2007 | 04:54 PM
what rpm?
customryder is offline
Old 06-29-2007 | 06:41 AM
monstaaa's Avatar
yes what rpm and what pitch props? i would venture to guess the herrings are 29's or maybe 31's buy the drop in rpm your describing.
try a set of 30 or 31 p 5 hydro's if your looking for speed . or go with a set of max's for the cruise plane and good top end
monstaaa is offline
sam edwards
Fountain
21
10-25-2008 11:16 AM
tssteph
American Offshore
6
09-14-2007 05:16 PM
311form
03-25-2003 08:33 PM
Fast Forward
20
10-20-2002 01:38 PM
mleslie951
Apache
2
09-30-2002 10:10 AM
