New Temp alarm units for Closed Cooling 454 Mags
Hello,
I bought a freshwater boat Scarab and brought down to FL so did closed cooling right away. But it runs @160-180 instead of the usual 125 degrees so the alarms keep sounding.
1. Is this even good for the engines since spec is 125 degrees?
2. WHERE can I find new Temp alarm sensors that will fire off at a higher temperature?
THANK YOU from a new boater!!!
Frank
Frank
