speedo problem >
speedo problem
speedo problem
Old 09-18-2007 | 11:10 PM
Default speedo problem
i have a bravo one outdrive and my speedo quit working, i followed the vac hose from the speedo back to the outdrive, i disconnected the vac hose from the outdrive and blew air into and it moved the speedo, has anyone had this problem before, could my outdrive be clogged or something? thanks for the help
drew300zx is offline
Old 09-18-2007 | 11:26 PM
The pick up hole is clogged on the drive. Happens all the time. The pickup hole is a little notch on the leading edge of the lower unit, about halfway between the cav plate and bullet. Just take a very small drill bit and twist it into the hole with your fingers to get the debris out.
Griff is offline
Old 09-19-2007 | 10:07 AM
i looked on the outdrive and cant find the pickup hole, does anyone have any pictures, thanks
Old 09-19-2007 | 03:49 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The red arrow is the speedo pickup location. They usually get plugged with a peice of wood.
US1 Fountain is offline
Old 09-19-2007 | 05:17 PM
thanks for the help
Old 09-19-2007 | 10:07 PM
AIR TIME's Avatar
there worthless, get a gps then you will now your real speed which is always 3 to 5 mph slower than the speedo art
AIR TIME is offline
Old 09-21-2007 | 12:34 PM
A problem I had with mine (Bravo I) is there is a small rubber hose in the drive that had blown apart. I had the boat pulled and was having a drive serivce/alignment done when they checked the hose. The tube from the speedo to the drive was fine and so was the pick-up but it was the small hose with the bend in it in the drive.
jswfl09 is offline
Old 09-25-2007 | 08:58 PM
Default Best help I've had
Thanks! i've been looking for that hole seems forever. Plugged full of stuff.
Mark Hulst is offline
heavyhauler
21
06-09-2008 07:36 AM
carcommander
4
04-24-2008 07:12 PM
sonic28
1
09-04-2007 05:47 PM
pol98xc6
1
05-18-2007 06:05 PM
