Blower Cam Choice
I'm starting my winter project. 25 Eliminator Daytona. 509 cid,8.5 to 1CR, Edlebrock performer rpm #6155 aluminum heads, B&M 420 blower, 2 850 BG prepped holley blower carbs, CMI E tops.Planning on 5 to 6 lbs boost. Suggestions for cam requested. I want to turn it to 6000rpm . Note: I need a relatively smooth idle due to running a Black Hawk drive. It needs to be able to idle around 700 in gear or docking / trailer loading will be nuts. It already does near 9mph at idle with a 500efi in it.
OK motor gurus, whats the best cam choice for this combination and any guesses on HP and TQ #s?
See my reply @ HOTBOAT, the same opinions were given here as well..............
Here's the link for my Offshore discussions.....
http://www.offshoreonly.com/forums/s...d.php?t=164018
You can get 2 diff cam manufactures make you a cam the exact specs and it will run diff.
Ramp profiles,degrees of opening and closing.
I would pm Bob RMbuilder
