Carb issue?
Old 11-01-2007 | 01:56 PM
razor1115's Avatar
Question Carb issue?
Guys,
I was fogging my HP500s the other day for winterization. I noticed, at idle, fuel dripping from the primary venturies. Is this a sign that the carbs need rebuilt, a gasket replaced? The boat does smell rich at idle wehn out running it...
Regards,
Z
razor1115 is offline
Old 11-02-2007 | 08:26 AM
Blown power valve.
Originally Posted by razor1115
Guys,
Regards,
Z
rdoactive is offline
Old 11-02-2007 | 10:34 AM
razor1115's Avatar
Originally Posted by rdoactive
Blown power valve.
Easy enough fix! Thought all the new Holley's had PV backfire protection built in?
Old 11-02-2007 | 03:01 PM
It might not be the PV. It could be a needle seat adjustment. Also, it could be nothing.
The angle of the boat is probably different on the trailer, than in the water. The forward angle on the trailer will fill up the primary fuel bowls higher and cause them to drip into the carb at idle. Check it with the boat in the water in the Spring.
Griff is offline
Old 11-02-2007 | 03:16 PM
razor1115's Avatar
Thanks Griff
Old 11-03-2007 | 07:44 AM
And if it's still doing it in the spring, in the water, perhaps the floats need adjustment from all the wave pounding...
nwimbush is offline
Old 11-03-2007 | 09:30 AM
baja36ft's Avatar
SOUNDS LIKE YOU GOT IT GRIFF BUT MIGHT BE A LITTLE DIRT IN THE SEAT,,,,
baja36ft is offline
YOLO
05-07-2008 10:15 AM
happy hours
6
01-13-2008 11:26 AM
MILD THUNDER
13
06-12-2007 06:05 PM
russ
0
07-21-2005 04:35 PM
ActiveThunderTodd
10
08-28-2003 10:13 PM
