For all of you engine guru's >
Old 01-08-2008 | 03:06 PM
LakeRacer's Avatar
Charter Member #9/ Moderator
Default For all of you engine guru's
here are the specs for the cam installed on my rebuilds.
226/234@50 - .587/.610 - 112lobe sep
I had 502's bored to 509's. Same heads with mild port work and larger valve's (same as hp500's) Flat top pistons, Eddie Marine thunder headers, roller rockers, and I kept the efi system. Had the computers reprogramed by Mark at Performance Marine in Louisiana.
My question is... what do you think the hp would be? Take your best guess as I won't be able to put it on the dyno. I had them re-built with longevity in mind and was wondering if I got any more power than stock 502's.
Art
LakeRacer is offline
Old 01-08-2008 | 03:40 PM
PatriYacht's Avatar
That looks like the 500EFI cam you're using. I'd guess a little over 500 hp.
PatriYacht is offline
Old 01-08-2008 | 04:19 PM
fantastixvoyage's Avatar
Come on Ian that's real world numbers...we're bench dyno'n here! I say 600hp minimum and will last 900 hours!!!
fantastixvoyage is offline
Old 01-08-2008 | 05:21 PM
Cam is a Crane 731 and just slightly bigger than 500hp cam. It should make 500-520hp at 5200 rpms.
Griff is offline
Old 01-08-2008 | 05:29 PM
I agree
Westcoast is offline
Old 01-08-2008 | 08:07 PM
Pat McPherson's Avatar
What's the compression ratio?
My Desk Top Dyno says around 500HP with 8.5:1.
Patrick
Pat McPherson is offline
Old 01-08-2008 | 10:51 PM
compression will be lower than stock. would be good for a blower though.
5050 is offline
Old 01-08-2008 | 11:55 PM
LakeRacer's Avatar
Yeah, what you said
Art
Old 01-08-2008 | 11:56 PM
LakeRacer's Avatar
My engine builder said with a flat top piston and a slightly bigger bore I should be at the same compression ratio or slightly higher than stock.
Art
Old 01-09-2008 | 06:07 AM
PatriYacht's Avatar
