For all of you engine guru's >
Old 01-09-2008 | 06:12 AM
PatriYacht's Avatar
Originally Posted by LakeRacer
My engine builder said with a flat top piston and a slightly bigger bore I should be at the same compression ratio or slightly higher than stock.
Do the math and figure in the deck hgt. the head gasket thickness and the chamber volume. It's the only way you'll know. If you aren't zero decking the block it may be lower than you think.
PatriYacht is offline
Old 01-17-2024 | 07:47 PM
Pnb
Im looking at buying Lakeracers old boat. But it looks like he hasnt logged on since 2018. Does anyone have anymore information on the engine work he had done. Will it run on 87?
Pnb is offline
RBeyer
60
03-19-2008 01:11 AM
29scarab
7
06-27-2005 02:41 PM
GO4BROKE
10-04-2002 05:37 PM
badboats30
08-26-2002 10:08 AM
