bellhousing? >
bellhousing?
bellhousing?
Old 03-01-2008 | 07:46 PM
Default bellhousing?
does anyone know if flywheel bellhousing is the same for 3.0 liter as small/big block? reason asking is that bought large coupler bravo bell for sbc and the dowel holes are loose, buddy has one off of 3.0 gm. without seeing it yet i think bolt pattern is the same. is my thinking correct? already know that the coupler hole measures the same. thanks
johnnyexcal is offline
Old 03-01-2008 | 07:54 PM
Michigan Mad Man
The early smallblock bellhousings had a smaller hole for the coupler. The bolt patterns and the dowel holes should be the same.
TylerCrockett is offline
Old 03-01-2008 | 08:06 PM
thanks, i've switched to big coupler/late model bravo 1 and needed bell, so i bought one then noticed it had loose dowels when i went to install , this puts me into the situation i'm in. buddys bell should work then considering for some odd reason his 3.0 liter boat that he scrapped had that big coupler on it . must be the high horse! ha-ha
Old 03-01-2008 | 09:46 PM
just had bud measure his dowel holes,his also measure .680 to .725 tapered from block side to transom. why is this 2 bells the same way or are they all gonna measure this? doesn't the dowels help for stabilizing the coupler alignment or am doing something wrong?
riski bidness
2
08-10-2006 10:02 AM
MILD THUNDER
11
10-18-2005 09:05 AM
ratman
12-10-2004 07:01 AM
jharran
Pantera
0
02-13-2004 04:55 PM
azlineman
3
01-18-2004 11:18 PM
