Thankyou RM Builder >
Thankyou RM Builder
Thankyou RM Builder
Old 04-15-2008 | 10:48 PM
CB-BLR's Avatar
Chris
Default Thankyou RM Builder
I would like to thank Bob Madera aka RM Builder for specing the parts for my 540. I am really pleased. Dyno pull is with all accessories installed and blowing through Dana Marine Torque-flow exhaust.
Chris
CB-BLR is offline
Old 04-15-2008 | 11:11 PM
Strip Poker 388's Avatar
Rob
I like the HP #'s from 4800 to 5900. that should pull some good #'s.Congrats , Bob is pretty sharp on designing a cam. He goes that extra info, unlike most cam manufactures,they usually don't ask much
Rob
Strip Poker 388 is offline
Old 04-15-2008 | 11:49 PM
The numbers look really good. I would think, prop it for 5400-5500rpms at wot as the spinning it 400 rpms faster for 10 hp isn't worth it.
Griff is offline
Old 04-15-2008 | 11:56 PM
CB-BLR's Avatar
Chris
We were going for a very broad torque curve, and gave up some peak HP to gain it.
Chris
CB-BLR is offline
Old 04-16-2008 | 06:45 AM
500 lbs of torque at 2500 rpm....awesome.
Pismo10 is offline
Old 04-16-2008 | 10:10 AM
Rob
but what does the 400rpm do for speed,mine was gaing 10 hp per 100rpm from 5800-6100,I prop it to 6000 for top speed, the capibilty doesent mean you run it there .
Old 04-16-2008 | 10:19 AM
KAAMA's Avatar
Thumbs up
Originally Posted by CB-BLR
I would like to thank Bob Madera aka RM Builder for specing the parts for my 540. I am really pleased. Dyno pull is with all accessories installed and blowing through Dana Marine Torque-flow exhaust. Chris
Congrats!!! Those are some very respectable/impressive HP/TQ numbers with a "Manifold" style exhaust system!!!
KAAMA is offline
Old 04-16-2008 | 10:32 AM
KAAMA's Avatar
CB...By the way, what size/brand of heads are you using? Also, was the engine dyno'd with or without sea pump, alternator, etc??? Was the exhaust system "wet" or "dry"? Just curious.
KAAMA is offline
Old 04-16-2008 | 10:58 AM
mrhorsepower1 is offline
Old 04-16-2008 | 11:08 AM
CB-BLR's Avatar
Chris
Kamma,
AFR 305 CNC, Dana Torque-Flow exhaust - wet, vortex collector sized for 540, with sea pump, alternator, power steering pump, water pump. 9.6 compression, victor manifold, HVH 1 inch super sucker, 1050 Dominator, Jessel rockers, Morel lifters, Bob's cam.
Looking forward to putting it in the boat next week.
Chris
CB-BLR is offline
