bottom staining >
bottom staining
bottom staining
Old 06-02-2008 | 07:46 AM
Default bottom staining
ok lets hear some fixes what helps to keep bottom from getting yellow one day in water and whole bottom is stained i know previous owner used on off occasionally but not all the time is there a fix for this ???
Baddogg is offline
Old 06-02-2008 | 12:36 PM
Muratic acid in a pump garden sprayer. Spray it on and then hose it off. It will take the stain off easily.
Do it in the street. Rinse very well. If the trailer is aluminum, avoid getting the acid on it as much as possible and rinse it asap. The fumes suck.
Griff is offline
Old 06-02-2008 | 12:55 PM
I usually use on off, works great. I work at a pool so we have muratic acid and I sometimes just grab jugs of it, you should prob dilute it a bit, or be real quick with a hose
Perlmudder is offline
Old 06-02-2008 | 01:10 PM
tssteph's Avatar
Toilet bowl cleaner. Sno bowl works great.
tssteph is offline
Old 06-02-2008 | 01:21 PM
Strip Poker 388's Avatar
Rob
I tried waxing it ,I think it made it worse the next time.
I use Starbrite hull cleaner from Wallmart
Strip Poker 388 is offline
Old 06-02-2008 | 06:36 PM
I Must Have Said This Wrong I Know How To Remove The Stains I Was Wondering If Anyone Knows Why Some Boats Get It So Bad I Use On Off As Little As Possible I Believe The Previous Owner Probably Used It A Little More Than I Do I Believe The More You Use It The Worse It Gets I Need To Know If Anyone Knows What Will Help Keep This From Happening So Bad Thanx
Baddogg is offline
Old 06-02-2008 | 06:57 PM
obnoxus's Avatar
Charter Member #1171
Toilet bowl cleaner,,,,, wont even have to scrub !!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-02-2008 | 06:59 PM
Once you start really hitting it hard and frequently with the chemicals it makes it worse... There is something on the new gelcoat that keeps it off longer... older boat... not much choice... just gotta keep hitting it. I have that problem as well... Clean er up she looks brand new... one day out in the salt and the stains are back. You should see it after our annual 2 weeks out. I guess thats why they invented bottom paint but of course non of us would go near it and loose MPH. Frustrating... but it is what it is.
Good Luck
Plaineman is offline
Old 06-02-2008 | 07:02 PM
bcfountain's Avatar
Registered User
i think the gel-coat wears or gets porious overtime.i just did my fountain,looks good...but for how long.they say after you on/off the hull,you should hit it w/aleast two coats of wax.i am with you though,i dont like the acid on the hull.
bcfountain is offline
Old 06-02-2008 | 08:30 PM
GO4BROKE's Avatar
FSR removes the stains. If very bad just let it sit on the hull for a couple days. My 386 had a terrible "coffee" stain on the bottem. A couple applications of FSR cleaned it up. If I'm leaving it in for a couple of days I put wax on the bottem but don't buff it off. Works pretty good. Don't use carnuba, thats fish food.
[img][/img]
GO4BROKE is offline
