aligning eng and trans
Old 06-24-2008 | 02:14 PM
Default aligning eng and trans
whats the right way to align the eng/coupler ant the trans input shaft,i locked it in gear and the thing still just spins?
dmaxx3500 is offline
Old 07-07-2008 | 07:47 PM
I believe it will spin freely unless the engine is running and there is pump pressure.
I see you are from chicago. Where do you boat?
MILD THUNDER is offline
Old 07-08-2008 | 09:04 AM
Wally's Avatar
Were doomed!
are you talkin as far as the outdrive end goes? like with the alignment tool for the bravo's/alphas? For a TRS setup its actually the same tool....only difference is theres an extra plate that goes on the end and will sit flush to the bell housing of the transom assembly. Look here: http://www.mercstuff.com/alignmenttool.htm
-Wally
Wally is offline
Old 07-08-2008 | 11:51 PM
no,im talking about the flywheel/coupler to the front of tranny, 2 and 3 went together like butter,no problem
Old 07-09-2008 | 06:40 AM
If you mounted the trannie and you can spin the output shaft, thats ok. Once the trans is bolted to the bellhousing, she's in.
If you are tryin to get the tranny mounted, but the splines wont engage in to the coupler, you may have to rotate the trans counter clockwise or clockwise till it slides in flush.
MILD THUNDER
2
09-07-2008 01:04 PM
Wally
6
06-27-2006 08:22 AM
Longrange4u
10
05-15-2006 08:47 PM
hystat
2
05-27-2002 05:35 PM
fstboater
3
03-21-2002 03:47 PM
