questions about procharging my boat
The motor is all stock and would like to procharge it. Would like someone that has had some experience with the procharger and if the 502 mpi needs any internal engine parts or can this just be a bolted on system. Thank you very much for your help.
Depends on how many hours you have and condition of gaskets,rings,brgs etc.If your buying a m-1 then you'll probably be OK but there is no guarantees. If your buying a m-3 and aw504 innercooler (which will allow you to run more boost in future then I would say pull heads,inconel valves,composite head gaskets etc plus OTHER upgrades-drive,oil cooler,hyd steering etc,Smitty
I did it with good success. If you have a smaller boat that you don't need to run at higher RPM you can expect good results because boost does not even come in until higher RPM's. Most of my engine hours were cruising and not even under boost. If you have a bigger boat that really lugs the motor/s you might want to think twice.
my boat is a 27 foot virage with 2 step hull it has a bravo three out drive and the motor has about 200 hours on it. it seems to run perfect and is running about 65mph now on gps all day long. do you think i can get close to 80mph out of it.
The boat planes easy and is on plane at about 16mph. do you think i have to many hours on the motor? I do have a brand new set of afr heads for a a 540 stroker motor should i put these heads on the 502 or bad idea? with procharger. or just use the stock heads?
I personally would be looking at a Whipple system instead but the I can tell you from having had a Procharger on a 502 on my old boat, they do make some HP.
that aside, you are very unlikely to get to the 80 mph mark because that Bravo 3 drive is going to severley limit you in several ways, prop selection and hydronamics. If you supercharge you should definitely consider installing a standard Bravo or better yet XR.
