Anyone know Trailering capacity for 2003 Z71 Avalanch
i didnt know you could get an 08 with 8000lb and the 4.11's. I tried to buy an 08 avalanche 2500 and they said the no longer make them, the best they could come up with for an avalanche was 7200lbs. I ended up buying a tahoe which can also tow 7200lbs, figured either way i was screwed for towing my clam
You are correct, 2500 3/4 ton option no longer available. Only options are 5.3L vs. 6.0L, 2wd vs. 4wd & 3.73 vs. 4.10 (not 4.11).
I've been towing my 30 Skater locally to the ramp (approx) 6 miles figuring if the boat weighed 6700lbs dry the boat & trailer might weigh 8500lbs. I was way off. I towed to a truck stop & dropped the boat & trailer on the scales, much to my surprise she weighed out @ 10,950 1/2 full of fuel. The auto leveling suspension is deceiving as I'm way over. Ordered a 6.0 gas 2500HD Crew Cab w/ 6spd auto w/ 3.73's.
I believe wheelbase & LT tires make the biggest towing difference from a weight handling standpoint. Tahoe has a pretty short WB, an Avalanche is equal to a Suburban (which is still available in a 3/4 ton).
Sydwayz has got all the facts. I said Z77 when I meant Z66, I just couldn't picture it in my head. Those are pretty rare in the southeast!
