drilling holes i the prop? >
Old 10-13-2008 | 12:26 PM
VP of the tickfaw200
Default drilling holes i the prop?
i have a 25' baja outlaw with a 23p 3 blade prop. i am new to all of this someone was telling me to drill a 3/8 inch hole in each blalde, and it would make it plain faster with out loosing any top end. is this tru or should i just change my prop? ( top speed is 63 with a 502, with a over 400 hours on the motor)
caseyh is offline
Old 10-13-2008 | 12:59 PM
What are you trying to achieve?
www.bblades.com Knos about Bajas call them.
...dont drill the holes!
Keith Atlanta is offline
Old 10-13-2008 | 01:04 PM
um, ya, do NOT drill holes in prop.. or the hull..
waterboy222 is offline
Old 10-13-2008 | 01:31 PM
Registered User
Some outboard props have vent holes through the diffuser to help with planing. At low speeds it allows exhaust gases to aerate the blades for faster planing. The vent holes only work on through prop exhaust boats anyway. Drilling holes in the blades definately won't help.
320es is offline
Old 10-13-2008 | 07:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Call us and we can help clear this up.
Don't drill holes in blades! Drill them in the outer hub only.
Boats without through hull exhaust also are affected by vent holes due to the incredible pressure differential created. However, through prop exhaust is more effected and the reason the concept came about.
B
[email protected]
bbladesprops is offline
Old 10-14-2008 | 12:13 PM
i was not going to drill holes in it anyway. i just didnt have a clue why you would do that. i am trying to get on plain faster and not hurt my top speed its only 63. what is my options?
caseyh is offline
Old 10-14-2008 | 12:40 PM
Send the prop to BBlades and let him work his magic.
Griff is offline
handfulz28
Do It Yourself, Boating on a Budget
8
03-05-2008 12:22 PM
DiamondPerformance
New Products and Member Discounts
3
05-31-2007 08:36 PM
pachangalpina
6
08-03-2005 10:40 AM
Quiet Storm
Detailing, Painting, & Fiberglass
6
05-19-2005 09:18 PM
Ran-Dom 32
04-29-2003 10:06 PM
