Question about replacing exhaust manifolds... >
Old 03-01-2009 | 08:35 PM
Default Question about replacing exhaust manifolds...
There are two ads on OSO for Gil Manifolds and tails. One add is for 2 sets off hp500's. The other sets are off of 500 Bulldogs. Will these work on a boat with trs dimensions ? I was thinking the bravos exit lower than the trs. Trying to get away from reversion problems. Any other options or advice?
Cold Sweat is offline
Old 03-04-2009 | 03:19 PM
KEPP's Avatar
Only the Best Will Do!
The Bravo tail pipes exit at a 14 degree down slope and are much shorter than the TRS tail pipes. Usually they are pointing in a far lower exit location than a standard TRS used. If your TRS pipes had quite a bit of downslope they may work. If your existing hoses are very flat you more than likely will have problems.
KEPP is offline
mslitti
General Racing Discussion
1
02-21-2009 09:58 PM
mslitti
02-21-2009 12:11 PM
1BIGJIM
2
07-13-2007 06:56 AM
cstobe
5
03-11-2007 09:25 PM
BajaBuddy
10
06-29-2003 10:25 PM
