Timing Gears >
Timing Gears
Timing Gears
Old 04-08-2002 | 02:58 PM
Default Timing Gears
Anyone here use timing gears instead of timing chains on their big blocks?? Any pro's and con's? Just wondering before I buy a set. You gotta love the sound of the gears whining!!!
Brian
tmthunder is offline
Old 04-08-2002 | 03:12 PM
Tinkerer's Avatar
Cool
The con is the noise. The pros are a stedier cam and some of the sets make cam timing adjustments very easy. I would get tired of the whine.
Tinkerer is offline
Old 04-08-2002 | 03:13 PM
imq707s
I've never ran a set of timing gears on a boat motor, but I was going to put a set on my drag car with a 350 sbc. I was told not to do it by everyone that I talked to about it. The gears transmit a ton of harmonics and vibrations into your valve train. A timing chain or belt absorbs most of the harmonics. The gear drives sound cool (if you like that constant blower whine sound) but I've heard to many bad things about them. I would stay away if I were you.
Old 04-08-2002 | 08:14 PM
Crazyhorse's Avatar
I've also heard about harmonics transmission with gear setups, but haven't actually seen any damage from it. But a chain setup is very cost-effective and just about bulletproof. I'll stay with the Cloyes Tru-Roller setup.
Crazyhorse is offline
Old 04-08-2002 | 09:17 PM
mxz800's Avatar
from what i have reead and been told the gear drive causes a lot of xtra harmonics, friction, and heat. that is why alot of the drag car guys are going to jessel belt drive setups. harmonics really play a role in engine life and those motors dont run nearly the hours or consistent punishment we do.
mxz800 is offline
nwimbush
0
10-13-2007 02:04 PM
QUIKDECISION
8
04-28-2007 04:40 AM
Smitty
7
05-10-2005 09:12 PM
84monza
3
12-05-2003 08:24 PM
