Go Back  Offshoreonly.com > Owners Forum > LaveyCraft
Interior Picts >
Interior Picts
Interior Picts
Old 12-20-2009 | 01:29 PM
Default Interior Picts
TV - Here are some pict of the interior of my 20.8 Sebring.
This was done three years ago By Ross at designer marine/Lavey.
Have you thought about external steering?
note : There is a strange compression artifact from my camera that causes the dash to look funky in some areas, these areas are smooth as a babys bottom.
UD
Attached Thumbnails Interior Picts-dsc09626.jpg   Interior Picts-dsc09623.jpg   Interior Picts-dsc09625.jpg
Uncle Dave is offline
Old 12-20-2009 | 01:48 PM
Default Another Thing....
Another thing Twisted V - is steering.
Your rig will not steer if you cross about 4-450HP barrier. The stock steering will not be able to overcome the water passing across the skeg and will blow steering fluid past the seals.
Do this too much and the steering will blow at speed and immediately and violently slam to the left or right - this will ruin your weekend.
UD
Old 12-23-2009 | 12:42 AM
Once I get the boat all fixed up and in the water the next thing will be external steering before I do an engine upgrade.
Is this thread only for us?
I really gotta figure out how fast I would like to go too.
twistedvelocity is offline
Old 12-23-2009 | 11:45 AM
This is "your thread" boss.
What are you doing now with what power and how does the boat like it?
What prop are you turning and what RPM?
UD
Old 12-24-2009 | 03:25 AM
She hasn't hit the water let.
It has a stock 350 mag.
from what I have read it should run close to 60.
I'm switching from the alpha to a bravo and im guessing that will slow me up alittle. The bravo I picked up came with a 23 mirage prop so ill be trying that one out first
Old 12-27-2009 | 01:38 AM
Were you happy with the speed you got out of the sebring or would you have liked to get more?
Old 12-30-2009 | 09:44 PM
Been out at Glamis hitting the sand dunes since Sunday.......
Yes and No, - depends on the engine - Ill try to explain.
Sort of - I got mid 80's out of the original b& M supercharged 383 - then I blew it up. I estimated it was making about 400HP.
Not happy - I rebuilt it with better and more aggressive parts and cam profile and it made 450 HP on the dyno when precisioned speed in orange county ran it. I got a few more MPH out of it maybe 87 - then blew it up in about a season and a half.
Moderately Happy- Then I put a 454 that made about 500HP I built in it and got right at 90, and I started on a project 406.
Very happy - I finished the 406 it dynod at about 500HP with about 500LB ft with a flat tappett solid cam, and about 550/500 with a hydraulic roller but at higher RPM, and I learned al about rev limiters and rev control with a hydraulic roller and that flat tappett deals when cammed properly are inherently self limiting and went back to the flat tappett setup.
I pulled and sold the 454 to a friend I sold my advantage jet boat to- and put in all the trick stuff you see now and got about 94 out of it when it was fresh.
I was happy with 94.
Its now back down to mid to high 80's after years of holding my foot to the floor for hours at a time, and in need of a rebuild.
UD
Old 12-30-2009 | 10:13 PM
What kind of parts did you use in the bottom end again?
Old 12-31-2009 | 08:55 AM
Im pretty sure in the 406 I used a lunati crank and stock length rods and I balanced it with Ross pistons and Childs and Albert ZGS rings.
Id have to go check the build sheet again, but Im pretty sure thats what I used.
Its been a rock solid engine for about a decade.
UD
Old 12-31-2009 | 12:12 PM
When it comes time I am thinking I would like to do a 427 stroker. I gotta figure out how fast I want to go
