Lower Seal leak?
Old 01-24-2010 | 07:37 AM
offthefront's Avatar
Default Lower Seal leak?
I have 2 Bravo 1 lowers that Supposely have 10 hours on them ... I installed the lowers and both have a slight leak ...about a cpl of Tablespoons per nite ...I have not run them yet ...Is there a chance that if these lowers have set for a cpl of years the seals would dry out and cause the leak? Just strange that both drive are doing the same thing ....m
offthefront is offline
Old 01-24-2010 | 09:40 AM
PAST DUE's Avatar
make sure that the o rings that go between the upper and lower are in place and in good shape second i would clean them good and see if you can see where the leak is after that pull them and pressure check.
PAST DUE is offline
Old 01-24-2010 | 10:53 AM
could be ... I was pretty careful when we slid the lowers on and I did not glue em in .....so its possible ....m
Old 01-24-2010 | 05:57 PM
don't forget the tiny oil passage "quad" seal or "O" ring depending on the year. You don't mention the age of the lowers but if there are fairly old they may not even have the oil passage on either one of the upper/lower. Not likely but I've seen that happen ages ago. Of course that is a major leak in that instance.
rhinoLX is offline
Old 01-24-2010 | 09:02 PM
Vinny P's Avatar
I hate the winter!!
Where are the drives leaking from? Where the 2 halves meet ? At the carrier?
Vinny P is offline
Old 01-24-2010 | 09:12 PM
Found it ....no O-ring on the Vertical Shaft .... can't believe I did that twice ..... thanks for the help ....m
Old 01-24-2010 | 09:30 PM
That would do it.
Griff is offline
