Propshaft Runout ? >
Propshaft Runout ?
Propshaft Runout ?
Old 04-20-2002 | 09:26 AM
rws's Avatar
rws
Default Propshaft Runout ?
I was checking some TRS prop shafts (between centers in a lathe) and I was wondering if any of you Drive Builders could tell Me what is acceptable.One runs out .004 and one has .008 runout.
Rob
rws is offline
Old 04-20-2002 | 10:10 AM
Mbam's Avatar
Offshoreonly Advertiser
Rob, try and measure it with V blocks if you can. I assume it is straight between the races, then has a bend in what would be the prop portion. Supporting the shaft at the 2 races, measuring at the end of the prop shaft .004 is OK, .008 is marginal.
Mbam is offline
Formula Outlaw
05-16-2006 05:16 PM
RJBBC
Checkmate
17
05-08-2005 01:07 PM
Intolerant1
23
04-01-2005 09:57 AM
EWB
1
09-15-2004 06:40 PM
Raypanic
6
03-11-2002 04:43 AM
