Ever seen 1 break like this? >
Old 05-06-2010 | 07:36 AM
boatman22's Avatar
Default Ever seen 1 break like this?
Has anyone seen one break like this before? If so what was the cause? XR/ITS Thanks for any info.
Attached Thumbnails Ever seen 1 break like this?-151-%5Bdesktop-resolution%5D.jpg   Ever seen 1 break like this?-147-%5Bdesktop-resolution%5D.jpg
boatman22 is offline
Old 05-06-2010 | 09:47 AM
Mr Gadgets's Avatar
Charter Member #601
One tooth snaps off, then it walks over the next two and pushes the opinion out the front.
Another case of XR upper gears snapping teeth off!!
Mr Gadgets is offline
Old 05-06-2010 | 12:27 PM
I've got one just like that
It's in my growing collection of junk XR parts.
It made a hell of a racket when it happened
.....didn't smell too good either.
JaayTeee is offline
Old 05-06-2010 | 12:43 PM
I have two cases with the front threads broken out.
Boat1 is offline
Old 05-06-2010 | 01:02 PM
His didn't smell too good either when I followed him back.
Busta is offline
Old 05-06-2010 | 03:20 PM
boatman22's Avatar
That was me farting......
Old 05-06-2010 | 03:21 PM
boatman22's Avatar
It only had 47 hours on it...came apart while cruising at 3800 RPM's
Old 05-06-2010 | 03:22 PM
boatman22's Avatar
Dick..is there a different pinion gear that I should use?
Old 05-06-2010 | 03:40 PM
Panther's Avatar
Frank's Marine Service
A majority of the drive failures that I've seen are in the 4k rpm range (3500-4500)...
Panther is offline
Old 05-06-2010 | 03:49 PM
JasonSmith's Avatar
40' of Baja boat with twin 575's will cause that.
Also, they never break WFO, always somewhere around 3000+ RPM.
JasonSmith is offline
