Alpha Trim Hose Replacement >
Old 04-25-2002 | 10:15 PM
klmken's Avatar
Default Alpha Trim Hose Replacement
How does one go about replacing one of the hoses that runs from the trim pump to the transom assembly? I can undo the leaky hose at the trim pump but have no idea where it attaches in the transom assembly?? Merc manual doesn't say!!
Thanks,
Ken
klmken is offline
Old 04-25-2002 | 10:41 PM
Tinkerer's Avatar
Cool
EASY -- Just remove the bolts holding the plate that the hoses conect to under the drive - next to the transom
Tinkerer is offline
Old 04-26-2002 | 06:45 PM
Don't use any thing but line wrenches on the hoses!
FloridianSon is offline
Old 04-26-2002 | 08:14 PM
doug hess
Before you try standing on your head in the bildge use the easy way outside where the trim cylinder hoses attach to the manifold block. Remove the two 1/4-20 NC bolts. Pull down the block. The hoses from the pump attach to the inside of that block.
Doug
NoQuarter
Drives and Lower Units
3
05-21-2007 03:46 PM
ferraristyle
08-15-2005 10:08 PM
Jeff Pierpont
1
03-28-2005 08:30 PM
Hiflier68
8
03-11-2004 12:02 PM
21_senza_383_2
3
03-24-2003 12:04 PM
