How much water presure is to much ? >
Old 06-06-2010 | 12:10 PM
Default How much water presure is to much ?
what is optimum water pressure at idle through wide open I am seeing over 30 psi at 6000 rpm
Smoothsix is offline
Old 06-06-2010 | 09:42 PM
ttt
Old 06-06-2010 | 09:47 PM
30 is ok,,,but i say 17-25 is optimum !!!!!
Which engine is it and does it have a sea-strainer ???
DareDevil is offline
Old 06-06-2010 | 10:11 PM
It is a 598 na, no sea strainer and I am bleading off the pressure out of the back of the intake through 2 #10 lines into 1 #14 through the transom. Oh yeah imco lower and more like 35 psi over 100mph
Old 06-06-2010 | 10:27 PM
35psi or more is starting to ask for problems. 20-25psi at WOT is about perfect. Idle usually barely reads anything on the gauge.
Griff is offline
Old 06-06-2010 | 10:35 PM
What should be my next move to try to reduce the psi
Old 06-06-2010 | 10:38 PM
I agree.
Old 06-06-2010 | 10:39 PM
if u pick up at the drive, u can block the holes on the lower..if u pick up at the transom , u can file back the pick up.
Other way would be to stick a press relieve valve in the IN line at 25 PSI and dump it over board !
Old 06-06-2010 | 10:40 PM
U say, 30 PSI at 6000 RPM,,now u say 35 PSI over 100 MPH.......how high do u rev a 598 ???
Old 06-06-2010 | 10:46 PM
I set up a temp gauge and had my passenger watch it we went 106 mph at 6300 rpm and he said the psi gauge hit 35 psi
