fram fuel  filter for 525 >
Old 11-17-2010 | 07:36 PM
drgnrydr's Avatar
Default fram fuel filter for 525
looking around for the fuel filter for my 525 I have been amazed of the cost & no cross reference for it . I found the fram g3727 is the exact replacement size wise . its a 10 micron filter . Anyone know if the mercuriser is a 10, 50 or 100 micron filter ?
I think the filter is one in the same, the fram filter had a recall & so did the mercruiser .
price on the fram is 10$ cheapest i have found the mercruiser is 35 all the way up to 65
drgnrydr is offline
Old 11-17-2010 | 08:07 PM
Default Fixx
Wix # 33481,,4 micron filter.
FIXX is offline
Old 11-18-2010 | 02:00 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I wouldn't even use Fram for my winter storage filter.
Go with the Wix. You can get them at Napa, and if you buy a handful they will knock the price down a few bucks.
Sydwayz is offline
Old 11-18-2010 | 06:51 AM
Airpacker's Avatar
ac delco gf652f about 12 bucks at any ac delco or gm store
Airpacker is offline
Old 11-18-2010 | 07:33 AM
drgnrydr's Avatar
thanks for the quick responces >
I perfer wix filters also but they did not list a cross reference of the merc pn ..
kinda suprised that the wix is a just 4 mircron . the fram has more than twice the filtration
drgnrydr is offline
Old 11-18-2010 | 07:54 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I buy by the case and split with a buddy. You can get the prices down to about $6-7. Check EBay.
Baja_342 is offline
Old 11-18-2010 | 08:01 AM
I think that you may have that backwards. I believe they mean it will filter down to 4 microns which is smaller than 10 microns.
28cigarettess is offline
Old 11-18-2010 | 08:14 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
But the Wix is the only one with the anti-drainback valve IIRC; preventing dry start up.
Sydwayz is offline
Old 11-18-2010 | 05:13 PM
drgnrydr's Avatar
Not trying to be a smart ass but you should not comment on what you dont know . It can be very misleading ..
Read up on micron sizing ! you are 100% wrong ..
drgnrydr is offline
Old 11-18-2010 | 05:54 PM
Default Fixx
the way i gather it is the filter will trap down to a 4 size micron spec of dirt,with that being said fram will trap a 10 micton piece of dirt..4 is smaller then 10 so i would have to say wrong...
read and look at the chart..
http://www.tpub.com/content/fc/14104/css/14104_153.htm
FIXX is offline
