7.3 idle surge
Old 01-01-2011 | 09:25 PM
bigboat28's Avatar
Default 7.3 idle surge
This morning my truck started having this issue. When I pulled in the drive and put it in park the rpm went up to around 1000 rpm the dropped down, then when I SHIFTED BACK into drive it did it again. It did it a few times getting it into the garage. Any ideas about what it is? The truck is a 2002 7.3 automatic. The truck has 119,000 miles on it.
bigboat28 is offline
Old 01-01-2011 | 10:10 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Have you had the CPS replaced under the recall?
Sydwayz is offline
Old 01-01-2011 | 10:36 PM
bigboat--what king of mileage do you get? I have 03 7.3 auto 4X4 No programmer all stock but I have 35's on it and only get 12 aroung town and 8 pulling my boat on trips.
Davidwrsmith is offline
Old 01-02-2011 | 08:22 AM
mrv8outboard's Avatar
coolrunning racing
Check your transmission fluid level.
mrv8outboard is offline
Old 01-02-2011 | 09:12 AM
bigboat28's Avatar
CPS has been relaced. It is a cc shortbed 4X4 auto with 33's I get like 17.9 on the highway towing almost 4,000lbs. It has a dp tuner which got me 1mpg. Just went to Florida the end of November with no load and got into the upper 18's mpg on the way down.
Old 01-02-2011 | 09:22 AM
take the chip or programmer out of it and see if it continues.
onefastt is offline
Old 01-02-2011 | 10:08 AM
Throttle Fever's Avatar
With the above. Check you EBPS (exhaust back pressure sensor) and tube. Right front of engine, tube runs off the exhaust manifold up to the sensor. Pull the tube and give it a good cleaning, along with the sensor. Pete
Throttle Fever is offline
Old 01-02-2011 | 10:16 AM
After that I would read codes and see if anything comes up. My next thought as long as all the simple stuff is ok (ieil condition, level, fuel, fuel filter, you get it) would be a ICP sensor. Let me know if you have any code and I can PM you a abbreviation list. Pete
Old 01-02-2011 | 10:56 AM
LapseofReason's Avatar
Is this only under cold start up ? They will idle them selfs up to warm up and it truns off soon as you hit the brake.
LapseofReason is offline
Old 01-02-2011 | 11:04 AM
Read the 1st post......
