need help on a helm/orbital valve i.d.
i am looking at a orbital valve which is a "helm" for a hydraulic system... if you dont know what i am talkling about chances are you wont be able to answer my qustion. i am trying to figure out if the valve i am looking at will work for a single ram hydraulic steering setup. it is a char lynn and tagged 40-97 & 2411071-002
any help would be greatly appreciated!
Look on the Eaton site for Steering Control Units (they don't call them orbital valves). I quickly found this:
http://hydraulics.eaton.com/products...CU-TS005-E.pdf and this http://hydraulics.eaton.com/products/steer_main.htm
You should be able to match up what you have, and we have contacted the Eaton reps for work. They were very helpful in answering our inquiries.
http://www.fluidpower.com.br/catalog...n_direcoes.pdf
thats what i dont get, its stamped char lynn.... we are thinking this particular one is not going to be big enough... but from researching yesterday i can decode the model numbers. thought i already had one lined up but we think that the ones we have on hand are too big
back to searching. thanks for the help guys!!
i do not know the size, it cam in the mail last night and didntt havemuc time to look at it. the part number on it is 18183 and its latham. bad thing about latham is there isnt much info out there on their products and so far i have not been able to find specs. it appears to me to be a newer model after comparing it to my buddies older set up he has on his trs drives. the orbital valve i was looking at was off of some golf course size lawn tractor, the ones we have sitting in the shop are for dual rams and the one of them is way too big, the other may work as a temp just to get on the water. you can get new ones for around 300 bucks, the one i asked about was 95 bucks. to a guy like me if i can save 200 bucks doing some research and buying a good used one then that leaves me 200 bucks for something else such as buying trim pumps for my k planes... sorry, i am stingy lol
back to searching. thanks for the help guys!!http://www.pirate4x4.com/tech/billav...ing/index.html
These are some of the steering valve part #'s you can use. Keep an eye on ebay for these part #'s. I got a new one for about $100.
http://www.midweststeering.com/index...parent=80&pg=1
