Trying to make 450hp >
Old 09-20-2011 | 11:28 PM
Artate78's Avatar
Default Trying to make 450hp
What gm head castings and valve sizes?
What cast iron intake?
What cam?
With 9.0-1 to 9.2-1 CR does it take to make 450hp with a .030 over 454 mark IV
I will be running emi manifolds wet risers through hull. And a 800 Holley DP. Or is this possible? Just don't want to build a pig. I have the block/ rods/ crank ready to go. Just need to know what heads so I can order my pistons.
Thanks Aaron
Artate78 is offline
Old 09-22-2011 | 09:32 AM
Ill make it really easy for you. Engine masters just did a 454HO buildup for a marine app.
Stock 454 shortblock, 236/242* hyd roller cam, dart 310 aluminum pro 1 heads, dart single plane intake, holley 1000 hp 4150. Engine made 525HP@5600RPM, and kept pulling to 6000 making power. 517FT lbs at 4800.
Only thing I might do different, is a little less cam duration, and a little more lift than the one they used. That should bring the peak HP down to around 5300-5400.
MILD THUNDER is offline
Old 09-22-2011 | 09:41 AM
"330 on roids" did 460hp @ 5200 for something a little milder/cheaper
Itsallgood995 is offline
Old 09-22-2011 | 09:44 AM
in my opinion,the cam selected is good,prop the boat to spin 5500 rpm,and u have a winner
mike tkach is offline
Old 09-22-2011 | 09:47 AM
What cam?
Thanks Aaron
Aaron,gm sells a crate motor,i think it is 425 hp 454.go on the gm performance website and check it out,i think with the parts they are useing,and a little bit more cam,450 is easile achieved.
Old 09-22-2011 | 10:04 AM
Is there a link or is possible for you to post the article? I'd like to read this.
endeavour32 is offline
Old 09-22-2011 | 10:05 AM
good option also
http://www.chevyhiperformance.com/te...ine/index.html
Old 09-22-2011 | 11:04 AM
Rookie's Avatar
Wouldn't an old Merc 420 spec engine with a nice hydraulic roller cam get you in the ballpark or a little more?? You could still use the GM rectangle heads and save $2000 over going with aftermarket heads. If you were going after market heads I would also go with the Darts.
Rookie is offline
Old 09-22-2011 | 04:31 PM
Artate78's Avatar
Thanks for all the response guys. Only thing didn't want to run aluminum heads or intake. Salt water eats them up.
Artate78 is offline
Old 09-22-2011 | 04:51 PM
What cam?
Thanks Aaron
9.6 comp
.30 over 454 (365 mag origin)
Dart 308's
Comp XM-270h-12 cam
AirGap intake
HP 500 Carb
IMCO EXHAUST MANIFOLDS
453 HP @ 5500
505 TQ @ 4300
Car Biz is offline
