500 EFI tulips valves. >
Old 04-18-2012 | 04:47 PM
Default 500 EFI tulips valves.
New valve springs on, and valves burned into tulips on 500EFI what`s the major fault?
502 Magnum is offline
Old 04-18-2012 | 05:22 PM
PROWRENCH's Avatar
Fatigued valves, not-so-great quality to begin with.
PROWRENCH is offline
Old 04-18-2012 | 07:33 PM
articfriends's Avatar
LEAN/sky high egts- I put a holley projection on a small block in a old truck I had years ago and tuliped the valves towing hard in the winter time because it wasn't rich enough, Smitty
articfriends is offline
Old 04-18-2012 | 09:35 PM
Leaned out. Check the injectors. They most likely need to be flow tested and cleaned. I tulip'd 6 out of 8 intakes and dropped a valve seat on a SB Mag motor when the injectors began flowing poorly.
Trash is offline
Old 04-18-2012 | 11:26 PM
When you did the springs, did you happen to make any other changes to the engine....ie. cam, bump in compression, etc.
Eddie
Young Performance is offline
Old 04-19-2012 | 04:59 AM
Default 500 EFI Tulips valves
Thanks for replys, Eddie I did not do the job myself,the former owner tels me that he put works to the heads with new Comcam springs,but I can see that the heads has been milled and has a milled surface.This motor supposed to have a serie #0M050186 and if I got it right it should be with H beems rods, this motor has the 502 pistons and rods,I know the first models 500EFI had mostly the same internals as a 502 Mag MPI (not heads,pushrods,lifters and cam) In this matter I dont know the part# on the Comp cam springs and the lifters looks not like the origin 500 EFI,the springs looked to me to be very stiff,appreciate your oppinions here,thanks.
Bjorn.
Old 04-19-2012 | 05:41 AM
just start over. you have no clue what was done right or wrong.
dereknkathy is offline
Old 04-19-2012 | 09:04 AM
what was the timing set at?
MILD THUNDER is offline
Old 04-19-2012 | 10:25 AM
JasonSmith's Avatar
+1 get out of the trick bag.
JasonSmith is offline
Old 04-19-2012 | 10:34 AM
Default 500EFI tulips valves
It`s right I have no clue what was done right or wrong here,but it`s nice to hear other guys experience about things in this matter,no I did not check out the timing befor I took it apart.
